LithiumKid1976
Hi
Ive been looking through the documentation for deploying the LSclient.exe using a .cdm file.
our logon scripts are in the .bat form. im not sure if there is any massive diffrent between the 2, but i cannot get the logon machine to run the LSclient.exe file .
the .bat file and the lsclient.exe are located at
\\ourservername\SYSVOL\Marine\scripts\test2.bat
edit of that .bat file shows this
C:\WINDOWS\SYSVOL\sysvol\Marine\scripts\LSclient.exe miinvser
running that .bat file from that machine, works
S:\>C:\WINDOWS\SYSVOL\sysvol\Marine\scripts\LSclient.exe miinvser
Lansweeper client
Connecting...
Success
so if any one can tell me how to incorporate all this into a .bat file, id appreciate it.
Regards
Damien
LithiumKid1976
hi Guys
i got it sorted by changing it to the following
\\servername\SYSVOL\Marine.ie\scripts\LSclient.exe miinvser
i tried this before, but i must have had the wrong path, once i changed it to this, it worked.
Regards
Damien
