Zuider
I've multiple errors DCOM (10009) in my system logs.
"DCOM was unable to communicate with the computer ip address using any of the configured protocols."
For example (in French sorry :p):
System 2010-04-15 09:25:40 10009 Error event DCOM xxxx DCOM n'a pas pu communiquer avec l'ordinateur xxxx en utilisant les protocoles configurés.
System 2010-04-15 09:26:27 10009 Error event DCOM zzzz DCOM n'a pas pu communiquer avec l'ordinateur zzzz en utilisant les protocoles configurés.
My firewalls are desactived by GPO.
Does anyone know how to clean these up?
Thanks.
16 REPLIES 16
Zuider
If WMI access is denied, what are the consequences ?
Nothing will work.
Then I don't think you can disable it.
Zuider
Isn't OK. Sorry.
I've always eventlog DCOM in "Events Viewer\System":
"DCOM n'a pas pu communiquer avec l'ordinateur xx.xx.xxx.xxx en utilisant les protocoles configurés."
Translate in English:
"DCOM was unable to communicate with the computer xx.xx.xxx.xxx using the configured protocols."
Error - DCOM - 10009
DCOM needs to be enabled.
Can you try this on the server:
# Click Start, click Run, type regedit, and then click OK.
# Locate the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole registry subkey.
# Right-click the Ole value, point to New, and then click DWORD Value.
# Type ActivationFailureLoggingLevel, and then press ENTER. Double-click ActivationFailureLoggingLevel, type 0 in the Value data box, and then click OK.
# Type CallFailureLoggingLevel, and then press ENTER. Double-click CallFailureLoggingLevel, type 0 in the Value data box, and then click OK.
You might need to restart the server.
Zuider
The script isn't OK: I made copy/past but it don't launch.
I change HLM\software\microsoft\Ole >> EnableDCOM : N (in defaut, EnableDCOM is Y)
But in Lansweeper, all remote computers are "WMI access denied"
So, it's no a solution.
How delete only eventlog DCOM and that Lansweeper works correctly ?
Zuider
Have you a news ?
Zuider
Thanks.
