Options
12-19-2008 03:45 AM
I downloaded the free trial and loaded it, then I purchased the Premium Package, but I have no idea how to make this thing work. Is there a users manual or anything? How do i get this thing up and running? Most things are relatively menu driven, but I see nothing that says "Scan Now" or anything of the like.
HELP this newby please....
Labels:
Options
12-19-2008 04:41 PM
OK, I have the active scanning enabled. It has found 22 computers on the network so far, but only one of them has been "scanned". Is there a way to "Scan Now" or some way to force a scan?
Thanks.
Thanks.
Options
12-22-2008 12:33 PM
Thanks.
The scanning takes place as soon as the computers are seen on the domain controllers.
You will probably have scanning problems (access denied, firewall, ...) please use the connection tester and the solutions in our knowledgebase to check for problems.
Options
12-19-2008 07:15 AM
When you download from the download page there is a pdf attached in the zip file (documentation.pdf)
direct link : http://www.lansweeper.com/documentation.pdf
Scanning is done by triggering lsclient.exe (from a loginscript) or by using active scanning.
