moulton
I was just wondering how long it takes(roughly) for the audit of all parts to take place following LSclient.exe being run on the workstation.
I'm trying to get a decent audit on our network, and as at a college most PC's are off for summer. have a temp in to run round logging them on etc, but how long will they need to be on for?
TIA
Doing a full scan for a pc in a lan connection (100mbit) takes 10-20 seconds max (depending on the speed of the computer)
You can configure the amount of simultaneous scan threads in the config file file of the service
