mrrrl2
Installation gives this error, anyone know how to get around this?
Operation Failed with 0x8007000B
An attempt was made to load a program with an incorrect format.
This error occurs during:
Running Postinstall tasks...
Configuring IIS x64 to allow win32 apps...
Running latest Lansweeper d/l. Box is MS Server 2008 R2 x64 with IIS 7.
6 REPLIES 6
mrrrl2
Install log sent.
Please mail it to lansweeper@hemoco.com
mrrrl2
Lansweeper apears to be working but we can't access the web site from the server or network. I understand that this is related to the error above, but here is more info.
HTTP Error 403.18 - Forbidden
The specified request cannot be processed in the application pool that is configured for this resource on the Web server.
Module IIS Web Core
Notification BeginRequest
Handler StaticFile
Error Code 0x00000000
Requested URL http://ufamonitor:80/lansweeper
Physical Path C:\Program Files (x86)\lansweeper\website
Logon Method Not yet determined
Logon User Not yet determined
•An ISAPI filter or custom module changed the URL to run in a different application pool than the original URL.
•An ISAPI extension (or custom module) used ExecuteURL (or ExecuteRequest) to run in a different application pool than the original URL.
•You have a custom error page that is located in one application pool but is referenced by a Web site in another application pool. When the URL is processed, it is determined by IIS that that it should have been processed in the first application pool, not the other pool.
•The Web site has multiple applications configured. The application this request is configured to run in is set to run in an application pool that does not exist.
mrrrl2
Sent to ? or post it as an attachment.
piersma_com
I can confirm this issue.
Installing LanSweeper on Windows 7 x64 is a real issue.
can't get it to run
had to install SQL2008 express locally
NIels
Could you send you install log file please. (should be in the lansweeper folder)
