JonasSwede
Hi!
I installed Lansweeper website on a IIS running three others sites, these sites are running with ASP 1.0.
When lansweeper was installed the other sites stoped working because they where changed to ASP 2.0.
Is Lansweeper setup changing this on install?
If ASP 2.0 is not installed, will Lansweeper install 2.0?
Lansweeper uses 2.0 framework and installs this if necessary.
We'll try to reproduce the problem, meanwhile you can just revert the other sites back to 1.1 to solve the problem
I got a lot of error logs saying that the IIS only could have one ASP version IIS configured. I got problems with Citrix Webinterface, that did not want to work after just setting it back to 1.0, i haf to recreate the site. It is an old version of WI do..
Should it be possible to run 2.0 on Lansweeper site and 1.0 on som other?
Is it possible to just install the website directory, so ones can setup the website controlled and manually in IIS ?
The website is in folder (default) c:\program files\lansweeper\website
You can manually create your own site pointing to this folder.
