wflorence
I copied the files as instructed on the upgrade, however I am not finding the lansweeperservices.exe on my server system. I did find the service folder but not the mentioned exe. I did a search and did find it in an upgrade folder. Does Lansweeper use the upgrade folders? Also when I access lansweeper via the web browser on my machine it still says 3.5.1 but from the server management consol its shows 3.5.2
I am new to lansweeper so help is appreciated. Thanks.
Wayne
wflorence
Never mind good to go....copied the new exe....renamed to what we had...all is good. Thanks.
wflorence
I have on in that folder:
errorlog.txt
helperfunctions.dll
lansweeper30.exe
lansweeper30.exe.config
srvinstw.exe
i dont see the lansweeperService.exe
Do i just need to copy it there?
Your service should be in folder c:\program files\lansweeper\service
The website shows 3.5.1 because you haven't upgraded your service.
