Ponchohobono
There are several devices that are not showing up in the IP scan. I don't even see an entry in the errorlog.txt file of it pinging the device but not finding any open ports. What can I do to troubleshoot further?
Thanks, Patrick http://patrickhoban.wordpress.com
Ponchohobono
It's an NT 4 workstation that is a DVR for cameras. It's not on the domain but as you can see it was being picked up by the IP scan as a NAS device until 8/28/2010. Did perhaps a Lansweeper upgrade change the way this device would be detected?
Yes, it is (correctly) identified as a windows machine now.
If you can close port 135 on that computer (disable dcom) it will be detected as a nas again.
This device will be skipped because is is marked as a windows computer.
What kind of device is this?
Ponchohobono
I should also add that these devices were being detected until 8/28/2010. Below is a screenshot of the device & the device tester output.
SNMP Not active or community name wrong
Port 135 is open
Port 139 is open
Port 445 is closed
MAC address: 00-00-50-04-FE-02
Netbios information not accessible
FTP port is open
FTP enabled
220 accutrack-108 Microsoft FTP Service (Version 3.0).
SMTP port is closed
HTTP port is open
HTTP server: Microsoft-PWS/3.0
HTTP title: Diebold - DVR Login
HTTPS port is closed
SIP port 5060 is closed
HP jetdirect port 9100 is closed
SSH port 22 is closed
Scanning done!
You can try the device tester and check the output.
Make sure the device is pingable and increase the ping timeout if needed.
