derek_rose
I have a report to show Windows Server 2008 and R2 - some of the 2008 keys work, none of the R2 keys work -
Windows Server (R) 2008 Standard without Hyper-V BBBBB-BBBBB-BBBBB-BBBBB-BBBBB 21/04/2010
Windows Server (R) 2008 Standard without Hyper-V BBBBB-BBBBB-BBBBB-BBBBB-BBBBB 24/05/2010
Windows Server 2008 R2 Enterprise BBBBB-BBBBB-BBBBB-BBBBB-BBBBB 21/04/2010
Windows Server 2008 R2 Enterprise BBBBB-BBBBB-BBBBB-BBBBB-BBBBB 24/05/2010
Windows Server 2008 R2 Standard BBBBB-BBBBB-BBBBB-BBBBB-BBBBB 21/04/2010
What else - all my scanning times are set to 0 so it almost appears like these machines haven't been scanned in quite some time, although there is no scanning errors on the properties of the machine in question
I went and looked in the list of Product Keys and actually didn't see any of these. Although, they are listed in certain machines with the current key state. I added an entry for DigitalProductID4 to see if it helps decoding. Any suggestions about the scan time and the keys not being decrypted without scanning errors?
jvf_registros
Create a new Product Key:
Windows Server 2008 // SOFTWARE\Microsoft\Windows NT\CurrentVersion // DigitalProductID4 // Microsoft
Solved for me.
Solved for me.
Thanks jvf - I thought I did that but just did it again and forced a scan, seemed to work for me. Only problem now is that it creates a duplicate under the keys in the machine properties. It still shows the decrypted key - wonder if it's appropriate to review the original key, or use the "has variations" value?
For now I'm good, but maybe an ehnancement otherwise it may be hard to track things accurately.
Keys decrypted as BBBB... are keys that cannot be decrypted by Microsoft design.
This are most likely MVL (multi volume license) keys that need protection
