alevisen
Well, this is the problem im having. From the Lansweeper webconsole i can't view computers. The page displays fine, but doesn't display computers.
I suspect that this deals with windows server 2003 logonscripts settings.
I've tried create a user and set the logon script for this user to execute a batch file that contains the following command:
\\<logon_server IP>\netlogon\lsclient.exe <lansweeper_server IP>
Then I login onto a computer with this user but nothing appears in the webconsole page.
What is wrong with this?
Please, I need to put Lansweeper working now!!!!!
Windows 98/me isn't supported
alevisen
Thanks for the response. Lansweeper is working fine.
Now, I'd like to know why Lansweeper doesn't display workstations with Windows 98 OS.
I've tried to execute "lsclient" from one PC running Windows 98 and a memory access error displayed. However, in the command line window there weren't any error messages.
Can someone help me?
Could you post the following information:
Name of logon script
Location of logon script
Contents of logon script
Configuration of Active Directory for the logon script (is it replicated to all domain controllers?)
alevisen
This is response after execute "lsclient".
-- LanSweeper client --
Connecting to 10.4.7.15: success
Sending data....success
It worked!!!!
I think the problem is with Logon script settings, because executing the file manually it worked.
Any help about it?
if you try from the computer manually: "lsclient <lansweeper_server IP>" what happens?
Do you get an error?
