Options
‎02-02-2012 10:28 PM
SOLVED: See last post.
We just performed an update 5 minutes ago (did a backup before hand). We are getting the following error when trying to remote control:
Lansweeper Error - Path not found! EDIT: This error is from Google Chrome, I.E gives: Error: the network path could not be found.
EDIT2: Running remote control from the server's I.E gives Error: 800A138F then points to the customactions.aspx page to configure I.E correctly.
The RC link points to: javascript:runApp('\\\\CLNTSVR-56\\lansweeper$\\lsremote.exe CO7WBLLFA /NP','false')
clntsvr-56 is our Lansweeper server name and CO7WBLLFA is a PC I am trying to remote to.
Under Remote Control custom actions we have: {actionpath}lsremote.exe {computer} /NP
lsremote.exe is located under: C:\Program Files\Lansweeper\Actions on our server.
We tried to restore our DB before the update (since the updated only effected service and website, not DB) and we are still getting the same error. We were a version behind the update. Window Server 2003 SP2 32bit.
Lansweeperuser is not locked in SQL Management Studio 2k8.
Latest version info
Service version 4.2.0.63
Webconsole version 4031
Database schema 17
Your lansweeper installation is up to date.
Tools version info
lsclient.exe 4.1.0.3
lspush.exe 1.0.0.157
lsmanage.exe 4.2.0.21
Lsremote.exe 4.1.0.14
Screengrab.exe 4.0.0.89
RemoteUninst.exe 1.0.0.33
Any help would be great.
Latest version info
Database schema 17
Tools version info
Labels:
Options
‎02-02-2012 11:55 PM
This was a problem in the installer, it's fixed in the current release.
Users affected by this problem should recreate lansweeper$ share on the lansweeper server.
Options
‎02-02-2012 11:53 PM
Emailed support, the bug has been fixed. Thank you for the quick response!
Options
‎02-02-2012 10:38 PM
SOLVED: After upgrading the version, the Actions folder under: C:\Program Files\Lansweeper Lost it's sharename, It should be: lansweeper$.
Resolution cross read from: http://www.lansweeper.com/forum/yaf_postst5384_Upgrade-from-4-1-0-27-to-4-1-0-29.aspx
Options
‎02-02-2012 10:31 PM
Also checked:
…\Lansweeper\Service\Lansweeperservice.exe.config
…\Lansweeper\Website\web.config
And the lansweeperuser password is correct.
