cvaleriy
I try to install Lansweeper 3.5 in virtual environment (Win 2k3 SP2, .NET 2) SQL is located at Win XP SP3, 2005 Express, TCP/IP and Named Pipes enabled. It clean installed.
Now I try to install LS to Win 2k SP4, in page "Lansweeper Database Configuration" write identical (as in Win 2k3) data. LS tell that TCP/IP or Named Pipe is not enabled. Trying to install to 2000 SQL - tell "Error while trying to get SQL Edition. Reason: Interface not supported".
Auth data are valid in both case, various scheme (SQL auth and Windows auth) not help.
Sniffing traffic show that from Win2k3 LS setup connect to ports >1024, from Win2K setup connect to SQL host via SMB to named pipes sql\sqlexpress.
What to do to install Ls to Win2k ?
7 REPLIES 7
slimbyte
cvaleriy, please let as know if, by installing MDAC v.2.81 on the Win 2000 machine, your problem is solved!
As a quick note: Lansweeper service does not work on windows 2000, all other component should work fine.
slimbyte
In order to install lansweeper in Windows 2000 environment, having SQL Server located on a different machine, you have to install latest Microsoft Data Access Components (MDAC) on that Win 2000 machine. I recommend you MDAC 2.8 SP1.
Also, make sure you specify the instance name in lansweeper wizard, eg HOST\SQLEXPRESS.
cvaleriy
Problem not solved, bypass it by install LS to Win2k3 Env.
cvaleriy
16.04.2009 17:49:11 - ------------ Lansweeper Setup Started ------------
16.04.2009 17:49:11 - OS: Microsoft Windows 2000 Service Pack 4 (Build 2195)
16.04.2009 17:49:11 - Inst: 3.5.6
16.04.2009 17:49:30 - Checking connection to HOST ...
16.04.2009 17:49:31 - Connection to HOST ... succeeded!
16.04.2009 17:49:40 - Checking rights for user: DOMAIN\user name ...
16.04.2009 17:49:42 - Checking rights for user: DOMAIN\user name ... failed!
16.04.2009 17:49:54 - Checking connection to HOST ...
16.04.2009 17:49:55 - Connection to HOST ... succeeded!
16.04.2009 17:51:27 - Checking rights for user: DOMAIN\user name ...
17.04.2009 9:00:41 - Checking rights for user: DOMAIN\user name ... failed!
17.04.2009 9:00:44 - Checking connection to HOST ...
17.04.2009 9:00:45 - Connection to HOST ... succeeded!
17.04.2009 9:00:49 - Checking rights for user: DOMAIN\user name ...
17.04.2009 9:03:16 - Checking rights for user: DOMAIN\user name ... failed!
17.04.2009 9:03:19 - Checking connection to HOST ...
17.04.2009 9:03:20 - Connection to HOST ... succeeded!
17.04.2009 9:03:24 - Checking rights for user: DOMAIN\user name ...
17.04.2009 9:03:25 - Checking rights for user: DOMAIN\user name ... failed!
17.04.2009 10:37:46 - Checking connection to HOST ...
17.04.2009 10:37:47 - Connection to HOST ... succeeded!
17.04.2009 10:37:51 - Checking rights for user: lansweeper ...
17.04.2009 10:37:53 - Checking rights for user: lansweeper ... failed!
Last user - lansweeper - in sql auth has all privelegies in MS SQL to All database, I try sa but always see "...Interface not supported", "...not have enough rights..."
Could you post the error log from the installer please (should be in the temp folder while installing)
cvaleriy
Reinstall MS SQL, now LS setup wrote "Error while trying to get SQL Edition. Reason: Interface not supported", then "Setup has detected that the currently logged user does not have enough rights... ". Try to auth win auth scheme and sql auth scheme - message are identical.
What to do ?
