avi
hi ,
i am using the latest version (premium ver) :
in my reports i can see that about 60 computers are having wmi errors ,my question is :
1) lansweeper are working only with wmi ?? (i mean if those 60 xps are having errors at the wmi ,so lansweeper will not be able to check those xp computers and report about those computer configuration ??)
2) how can i config lansweeper that will use another compement instead of wmi ? (its possible ? ,wmi is little problomatic compement ,can i configure lansweeper to user remote registrty ??)
3) how can i tell lansweeper to run agian scan of all the computer in my domain ? how can i schedule scan of all my computers every one week ?
respectfully,
avi azerrad
Access is denied normally means that the account used for scanning does not have administrative permissions on these clients. (firewall isn't the problem)
avi
those are the erros:
(please notice that there isnt any firewall and i already done all that said in the lansweeper articles...include the script that not working..
Access is denied 0x80070005 (opal-0781.Mivtachim.co.il, OPAL-0781, 10.40.4.122) 31/08/2009
PASZAHAV-BINYAN Access is denied 0x80070005 (PasZahav-binyan.Mivtachim.co.il, PASZAHAV-BINYAN, 172.16.0.104) 20/12/2009
RANL-0971 Access is denied 0x80070005 (ranl-0971.Mivtachim.co.il) 13/08/2009
RISHUMIT-2008 Access is denied 0x80070005 (rishumit-2008.mivtachim.co.il, RISHUMIT-2008, 172.16.2.150) 27/12/2009
SHAGAI-0517 Access is denied 0x80070005 (shagai-0517.Mivtachim.co.il, SHAGAI-0517, 192.168.16.40) 22/12/2009
TESNET-010776 Access is denied 0x80070005 (TESNET-010776, 10.40.4.214) 10/11/2009
ZKEMI-01 Access is denied 0x80070005 (ZKEMI-01, 172.16.3.225) 20/12/2009
ZOOMIXSRV Access is denied 0x80070005 (zoomixsrv.mivtachim.co.il, ZOOMIXSRV, 10.0.0.5) 27/12/2009
AZNB-PC Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED)) AZNB-PC (172.16.4.54) 11/03/2009
BENSASON Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED)) BENSASON (172.16.3.186) 11/03/2009
DGNR-PC Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED)) DGNR-PC (172.16.3.189) 21/01/2009
IRIS-XP Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED)) IRIS-XP (172.16.3.13)
respectfully,
avi azerrad
1) Yes, WMI is required, which error do you get? 99% of problems are caused by a firewall, see http://www.lansweeper.com/kb/notfound.aspx
Which is the exact error you get?
2) You can't
3) When you enable active scanning this is not required.
