ratiopharm
After upgrading to 3.5 I tried to launch report builder and received this message when trying to connect to the DB. I can use SQL express and connect to the server . I copy and pasted the new license key for the upgrade. I am also having problem using the tools on the action screen
8 REPLIES 8
Could you post your lansweeperservice.exe.config file and the errorlog.txt file please.
ratiopharm
after pasting the licence key an ini file (rep.ini) was created , contents below. This info is on the screen when opening SQL express
[Lansweeper]
Database=lansweeper32
Server=CA-W-4040\SQLEXPRESS
Integrated=1
I tried you license code with the same build as the report builder and it worked without a problem.
Are you sure that you are connecting to the correct database?
Could you PM me your license code please, I'll try to reproduce the problem.
ratiopharm
None, in fact I had to copy and paste the license key when downloading the premium tools and had no errors doing that
When you copy/paste the license key did you get any error when you clicked on "validate license"
ratiopharm
I attached the error message above
Could you please attach your error message
