hatrantator
Hi guys, i hope you can help me.
After updating the server, our bookmark-widgets don´t work anymore.
Example: Link in bookmark widget is "192.168.1.1" but if i click on it the browser redirects me to "192.168.10.10/192.168.1.1" in that case "192.168.10.10" would be the lansweeper server adress.
I also get a Webserver Error which says "A potentially dangerous Request.Path value was detected from the client."
Changing the web.config only gets rid of the Webserver Error and gives me 404 Error (because the link adress still contains the lansweeper adress for some reason)
why would he put his own adress into the link?
This issue was fixed in Lansweeper version 5.3.0.28, which we released at the end of last week. You can update to the latest Lansweeper release by following the instructions in this knowledge base article.
Michael_V
There will be a fix for this soon (most likely tomorrow)
stiwa
Same issue here, seems to be a bug in version 5325, it worked in 5324.
