ccdesktop
Hi - we have a few pcs in vbery low bandwidth sites and want to only scan them very periodically.
It seems if I was to add them to Computer Exclusions then they will NEVER ever be scanned regardless if I trigger a manual scan / rescan etc.
Is there any way to somehow say - don't scan a PC EVER except when I trigger it or to NEVER scan it using the normal Active Scanning / logon script method but schedule it to scan once a week or something...?
I guess I could move it to it's own OU or something - but I don't really want to do this...
Any ideas...?
Cheers
Yes. LsPush is a small executable run on the client machine. It takes a full local inventory of the client machine by itself and does not rely on the Lansweeper service to do the scanning. So LsPush is not influenced by the settings in your configuration console.
ccdesktop
Will the schedule work even if it is in Computer Exclusions....?
Thanks.
Use lspush in version 4.2 beta.
You can set up a schedule on the computer to run it every week.
