RAFF37817
I am having a strange error in my LS logs.
After server weeks of running LS without issue. I changed the credentials the service uses to another account.
As you can see by the log snippet below, it does not want to start properly.
I tried putting it back to the original credentials and got the same error.
I did validate that this machine can talk to and see Active Directory using our support tools.
I also tried using a backup copy of the Lansweeperservice.exe file thinking the original may be corrupt but I still have the same error.
Rebooting the server did not help either.
What else can I try?
***** begin log snip *****
6/19/2009 1:25:02 PM: Stopping service
6/19/2009 1:25:06 PM: Database connection successful, starting up service
6/19/2009 1:25:06 PM: NOAM\LANSWEEPER_SERVER$ Active directory computer lookup Unknown error (0x80005000)
6/19/2009 1:25:07 PM: Logon failure: unknown user name or bad password.
at System.DirectoryServices.DirectoryEntry.Bind(Boolean throwIfFail)
at System.DirectoryServices.DirectoryEntry.Bind()
at System.DirectoryServices.DirectoryEntry.get_AdsObject()
at System.DirectoryServices.PropertyValueCollection.PopulateList()
at System.DirectoryServices.PropertyValueCollection..ctor(DirectoryEntry entry, String propertyName)
at System.DirectoryServices.PropertyCollection.get_Item(String propertyName)
at LansweeperService.LS_ActiveDirectory.EnumerateDomainControllers(LS_Domain Mydomain)
6/19/2009 1:25:09 PM: SMOSVR2435 User lookup Unknown error (0x80005000) DOMAIN\UNRELATED_SERVICE_ACCOUNT
***** end log snip *****
Thanks,
Raf
RAFF37817
That was it! Thanks!. I had forgotten that I also used the alternate credentials tab - once I changed the passwords there to match that of the LS service and restarted it, it all worked.
Thanks, again.
Did you also change the alternate credentials tab?
