ueteam
Morning,
I have setup the path in the console for all the actions and the lstrigger seems to fail. The other actions do work; I even tried running from the cmd on the server and I see it "connecting" then a "Failed" error.
Also screengrabber work, but the image is blank.
Any ideas?
Thanks,
11 REPLIES 11
ueteam
I found the answer:
I forgort to rename the config file when I upgraded to premuim.
I knew it had to be something that happen after the upgrade.
That also resolved the trigger issue.
Thanks again and great product, keep up the good work.
ueteam
<?xml version="1.0" encoding="UTF-8"?>
<configuration><appSettings><add key="ConnectionString" value="Persist Security Info=False;Data Source=UEBACKUP\SQLEXPRESS;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=mysecretpassword0*"/>
<add key="ConcurrentThreads" value="40"/>
<add key="ListenPort" value="9524"/>
<add key="Activescanning" value="1"/>
</appSettings></configuration>
It looks like your service is not running al all because the "connectionstring" part cannot be read.
Most likely cause of the problem is a line break between "initial" and "Catalog" in your config file.
Could you upload your config file to verify this please.
ueteam
I checked the service version and it is the Premium version,
Here is the config:
<add key="Activescanning" value="0"/>
ueteam
I also noticed that since I installed the premium pack, the last scan was when I performed the service update.
I have login scripts for the lsclient as well.
Also I checked the error log and this is what is present since the update:
11/12/2008 4:06:56 PM : Cannot connect to database, check your config file, will try again in 1 minute
The ConnectionString property has not been initialized.
11/12/2008 4:07:56 PM : Cannot connect to database, check your config file, will try again in 1 minute
11/12/2008 4:08:56 PM : Cannot connect to database, check your config file, service will be stopped
11/13/2008 9:32:26 AM : Stopping service
11/13/2008 9:32:28 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/13/2008 9:33:28 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/13/2008 9:34:28 AM : Cannot connect to database, check your config file, service will be stopped
11/13/2008 9:45:00 AM : Stopping service
11/13/2008 9:45:01 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/13/2008 9:46:01 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/13/2008 9:47:01 AM : Cannot connect to database, check your config file, service will be stopped
11/14/2008 8:31:27 AM : Stopping service
11/14/2008 8:31:32 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/14/2008 8:32:32 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/14/2008 8:33:32 AM : Cannot connect to database, check your config file, service will be stopped
11/14/2008 8:39:39 AM : Stopping service
11/14/2008 8:39:40 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/14/2008 8:40:40 AM : Cannot connect to database, check your config file, will try again in 1 minute
11/14/2008 8:41:40 AM : Cannot connect to database, check your config file, service will be stopped
ueteam
Here you go
Could you send me a screenshot of the command window when you try the lstrigger manually please.
ueteam
Yes
Yes and
Yes, and I even tried restarting the service.
ueteam
\\server\share\lstrigger.exe servername {computer} {domain}
Screengrabber is working.
By the way, great product so far.
One request would be better documentation.
The lstrigger is not working by the way.
