Sachin
Hi Support
I am now in Lansweeper 4.0 and it is amazing with new features and options .
I am using WSUS for windows patch management. and in the Lansweeper console i can see "Patch: Missing patch for the conficker worm" .It will be greate if you can specify which patch/patches are checking by lansweeper to confirm the system is patched for conflicker.?
I am having Windows XP ,vista and windows 7 systems in my network
The report was removed from the latest version because it was out of date.
Conficker : http://www.microsoft.com/security/worms/conficker.aspx
Matty
I am also using WSUS for patch management and im unable to establish which hotfix\update this relates to. Please advise.
M@TY
You can take a look at the definition of the report to see the KB number.
