sjohnson
We have some Wyse thin clients that are showing up with odd manufacturer/model information and it is more difficult to track down in the web console. For example:
Manufacturer: CN333_
Model: AWRDACPI
should really be:
Manufacturer: Wyse
Model: V90
I know this is due to the information provided from the hardware, and not a fault of Lansweeper scanning, but is there a way in the database I can modify "CN333_" to be "Wyse" and "AWRDACPI" to be "V90" for all devices and future devices (not manually changing each machine)?
http://www.sqlteam.com/article/an-introduction-to-triggers-part-i
sjohnson
OK. Unfortunately I have no idea how to do such a thing, is there any way you could point me in the right direction?
There's no easy way to change this for future scans, the only thing I can think of is a trigger on the table which replaces the values upon update (note that we don't support this)
sjohnson
They show up under Workgroup in Domain overview. Strangely they show up under the server column though...
Are these devices or computers?
If it's a device could you provide the snmp oid.
