gnohs
Is there a way to set a group for a remote scanning server? Lets say new devices are found on site a I want those devices to be tagged with "Group A"?
I have multiple companies that I am trying to use this software with and some have the same ip address scheme. I can see this getting confusing when trying to manually set groups as I will not know which site its coming from.
You can create a dynamic asset group under Configuration\Asset Groups. Use the "scan server" filter to have assets automatically added to a group based on the scanning server that last scanned them.
There's a built-in "Scanserver Assets Overview" widget as well that you can add to your dashboard. It allows you to quickly see a list of assets scanned by a specific scanning server. In reports, use the tblAssets.Scanserver field to determine which scanning server scanned an asset.
