pfrench1
Just a general question; my enterprise environment is best served by using multiple LS servers.
Can I have all of these servers use the same external SQL database?
My plan is to have the DB on its own SQL box.
Instructions for configuring a multi scanning server setup (with a single database) can be found on page 17 and beyond of our online documentation: http://www.lansweeper.com/documentation.pdf
You are actually meant to point all scanning servers to the same database. If you set up separate databases, each installation will be self-contained and you won’t be able to view data from location A in installation B or vice versa.
