adon
I am trying to install 3.1 for the first time. I enter the database server name and click on next and i get
runtime error (at 30:645):
Nil interface exception.
10 REPLIES 10
adon
I got it.
it works
thanks
adon
is it under downloads?
I've uploaded a new installer which should fix the problem
adon
database is installed as the default intance on gai-apsv. I also tried another server that is gai-mgmt\sqlmgmt. i got the same error
adon
actually i have tried to install it on 2 different server and different SQL servers as well
adon
Your computer : GAI-SMS >> Yes
Computer where you want to install the database : GAI-APSV >> Yes
Some questions:
Is the GAI-APSV a sql2005 server? >> this is SQL 2000 with SP4
Do you have administrative permissions on the database server with your current logged on administrator account? >> Yes. I use this login all the time to create DBs.
To get the details right:
Some questions:
adon
yeap here you go
Sorry, but is it possible to attach a little bigger picture, I cannot read the text on this one
