Lansweeper tries to detect what type of device is discovered by the snmp OID.
You can help extending this database by posting your list of devices where the type is incorrect discovered.
After you made the correction please upload report "Device unique SNMP OID"
32 REPLIES 32
joegasper
Device is a printer
Model: KONICA MINOLTA bizhub 600
Description: KONICA MINOLTA bizhub 600
ObjectID: 1.3.6.1.4.1.18334.1.1.1.2.1.4.4.2
joegasper
In the tsysOIDlookup table, we have:
OID = 1.3.6.1.4.1.11.1, Model = HP LaserJet 1022nw
Running device tester against two of my devices, they have that same OID, but are different model printers:
10.249.18.21 Ping OK
SMTP port is closed
SNMP Active
MAC address: 00-12-80-49-4A-44
FTP port is closed
Telnet port is closed
SMTP port is closed
HTTP port is open
HTTP headers:
Transfer-Encoding: chunked
Pragma: no-cache
Cache-Control: no-cache
Content-Type: text/html; charset=UTF-8
Expires: Thu, 01 Jan 1970 00:00:00 GMT
Server: Virata-EmWeb/R6_0_1
HTTP title: HP Color LaserJet 2820 / 10.249.18.21
HTTPS port is closed
SSH port 22 is closed
Device is a printer
Model: HP Color LaserJet 2820
Displayname: NPI21FF8C
Description: HP Color LaserJet 2820
Contact: helpdesk
ObjectID: 1.3.6.1.4.1.11.1
10.249.18.34 Ping OK
SMTP port is closed
SNMP Active
FTP port is closed
SMTP port is closed
HTTP port is open
HTTP headers:
Pragma: no-cache
Date: Thu, 1 Jan 1970 0:0:0 GMT
Expires: Thu, 1 Jan 1970 0:0:0 GMT
Server: $ProjectRevision: 4.0.2.38 $
HTTP title: HP Color LaserJet 2600n
Displayname: banetprn714004
Description: HP ETHERNET MULTI-ENVIRONMENT
What I seen the device listing as Model for these is what is in the OID database (HP LaserJet 1022nw).
Can you do something like this to populate the devices Model?
First use the SNMP Model field, if empty then
SNMP Description field, if empty then
use the the OID table
joegasper
With the first beta, I could see most Model types correctly, but a few of my devices only allowed "public" for the get community name. I went through all my devices and changed them to "public". Deleted all the devices, reran the scan using the new community name of "public", and all the devices looked great (that were known).
With the March 2nd beta reinstall, I just get below (I've confirmed my scan settings - spelling, case):
Type Model Vendor
Printer Dell 1815dn Samsung Electronics Co., LTD.
Printer HP Jetdirect Hewlett-Packard
Printer HP LaserJet 1022nw Hewlett-Packard
Camera Lantronix Pronet GmbH
Host Lexmark Optra Lexmark International
I had actual model numbers of all the printers...
Could be a problem with snmp timeout or community name wrong.
Was the description changed or blank during the last scan?
There was no changing of settings on the physical devices. Installed the March 2nd beta and that seems to be when the info in device database started to be different (fresh database).
Some of my HP printers were showing the correct printer model number, but now they just show as HP JetDirect in the model field. Ex:
10.5.123.22 Ping OK
SMTP port is closed
SNMP Active
FTP port is open
FTP enabled
220 JD FTP Server Ready
Telnet port is open
SMTP port is closed
HTTP port is open
HTTP headers:
Server: HTTP/1.0
HTTP title: Hewlett Packard
Device is a printer
Model: HP LaserJet 4000 Series
Displayname: OFANETPRNCRI006
Description: HP ETHERNET MULTI-ENVIRONMENT,ROM G.08.08,JETDIRECT,JD30,EEPROM G.08.49
ObjectID: 1.3.6.1.4.1.11.2.3.9.1
joegasper
Device scanning seems to have changed for me with the March 2 beta.
For example, with the first beta, for my Dell W5300dn, the Model and Vendor were correct (model = Dell Laser Printer W5300 version 55..., Vendor = Dell).
Now listed for this system: model = Lexmark Optra, Vendor = Lexmark International.
The Dell's have Lexmark internals, true. But the correct desc/vendor was being pulled previously.
Also, these models are now listing as hosts, not printers like before.
The Location, and Display name haven't changed and are correct.
Running 4.0.0.8
Running 4.0.0.8
Could you post the output of the device tester please.
Running 4.0.0.8
10.227.155.49 Ping OK
SMTP port is closed
SNMP Active
MAC address: 00-04-00-3D-8A-9A
FTP port is closed
SMTP port is closed
HTTP port is open
HTTP headers:
HTTP title:
Device is a printer
Model: Dell Laser Printer W5300 992P135 551.019 --- Part Number ---
Displayname: prn031
Description: Dell Laser Printer W5300 version 55.10.87 kernel 2.4.0-test6 All-N-1
Contact: helpdesk
ObjectID: 1.3.6.1.4.1.641.1
loerdy
Snmp OID: 1.3.6.1.4.1.343.2.19.1.1.2.1.1
Snmp Description: Intel Modular Server System
http://www.intelmodularserver.com/
new category for blade servers needed?
