digipoint
Hey all
Im trying to perform the new installation of LS
i'm following the giude lines in the pdf,
i'm enabling the TCP and named pipes.
and still during the installation of MS i get the error
In order to succesfully connect to the SQL server, following items must be accomplished on the SQL server side
Protocols Named Pipes and TCP IP must be enabled.
SQL service browsing must be running.
please read LS documentation....
The SQL is installed on the same server.
HW setup is same as 3.2 version. that i disabled.
OS is 2008 IIS7, i tested the beta on this and it worked fine
any ideas ?
http://www.digipoint.be/
digipoint
hey
ive checked it al and i found some sql left-overs from uninstalling, it solved the problem :d/ , i can continu the configuration of it
digipoint wrote:
hey
Could you please provide the details about these leftovers so we can update the installer.
Could you post screenshots of the screen where you fill in all the sql server details please.
Are you able to connect with another program to the sqlserver?
