dickson2u
Hi, i am new bird here.....
I had go through the documentation, and install lansweeper into server.
My question:
1) 1 have AD and domain controller, but there is no computer join domain.
is it necessary that client has to be join domain?
2) IF MY CLIENT WITHOUT JOIN DOMAIN, if i had upgrade to premium version which have active scanning, does it able to scan the network and collect all the information?
3) hence my client computer are not join domain, i had done what ever the documentation step from page 12 the logon script, i put in the startup.vbs in to 1 client compuer but it have error path not found...is it when using this scipt require the computer as a join domain?
I'm not sure if I understand the question right:
Is the server where you installed lansweeper on part of a domain?
If not then you will need the premium alternate credentials to scan other domains or computers.
