paprita
Some PC's on my network can't be reached by LS.
This is the connection tester:
DNS test
Is this the correct remote IP: xxx.xxx.xxx.xxx
If not, please check for DNS problems
Server RPC non disponibile. (Eccezione da HRESULT: 0x800706BA)
Remote WMI test
Tried to understand using your Knowledgebase but nothing is going ... RPC server is off and I can't try WMI service.
Can you help me?
Thanks.
paprita
I was right ... problem solved ...
paprita
Probably I found the problem ... DNS and IP address ... now I try to solve it ...
