cheche
Hi, I have a problem with the last upgrade. The wizard doesn't detect my database version and checks the database upgrade checkbox but i can't uncheck it. My database version is ok but I changed its name and its credentials.
Is a problem update database again? Upgrade will change anything?
Thanks.
cheche
Can I change credentials?
Yes
Don't change the name or you will be in trouble with future updates.
You can manually run the sqlscript upgradescript3.sql
