ToddHB
 just installed Lansweeper on a Debian System like described here: https://community.lansweeper.com/t5/install-network-discovery/install-network-discovery-linux/ta-p/8...
When looking into appsettings.json there is no part HubUrl? What am I missing?
Just want to get that piece of discovery up an running.
Thibo
Hi there,
The HubUrl parameter should be included in the appsettings.json file of the lansweeper‑network‑discovery‑it‑sensor component, located at /opt/lansweeper-network-discovery-it-sensor.
If you open the Network Discovery Hub on port 59525 and check the Sensors section, you see the sensors the Hub already knows. If it’s listed there, the sensor and hub are already linked, and the HubUrl is set correctly automatically.
