rwoodard
I'm tasked with getting some of the newer Adobe products entered in so Lansweeper can pull the keys for us. (We have the premium version and it's already pulling the keys correctly for other products)
I need:
Photoshop CS4
Photoshop CS5
Acrobat 9+ (and Pro)
I cannot seem to find the registry locations to insert into the configuration - I've tried a few different ones but no luck.
Any information as to what to enter in would be great.
Thanks in advance,
Ric Woodard
We have not been able to find additional Acrobat registry locations. The locations listed in the configuration console under Scanning Options\Product Keys and in this thread are the only ones we have been able to pinpoint.
dkir
Hi there,
Is there any update on the topic Acrobat X serials?
We have not been able to definitively determine registry locations for these versions. Logic would dictate that they follow similar formatting, but we have not been able to verify this.
rwoodard
What about Acrobat 9 Pro and any newer versions of Acrobat?
For Acrobat 9, please try the following registry location:
HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Adobe Acrobat\9.0\Registration
Value: SERIAL, type: Adobe.
We have not been able to track down registry locations for the other product keys.
