Tomas
I’ve posted this partly as an answer already but will add a more detailed instruction here since it’s been an extremely helpful Asset Action which i think should be included in the next release
BluesScreenView.exe
Displays the information of all crashes In one table by scanning minidump files created during a BSOD
1. Download BlueScreenView - > http://www.nirsoft.net/utils/blue_screen_view.html
2. Copy BlueScreenView.exe to your Lansweeper Actions folder '\Lansweeper\Actions'
3. In /Configuration/AssetPages/ hit 'Add Asset Action' and add following Action:
{actionpath}BlueScreenView.exe /LoadFrom 1 /MiniDumpFolder "\\{smartname}\c$\Windows\MiniDump"
bsodview
bsodview2
Tomas
nice find, thx i changed it
aeble
Hello Tomas and thanks for your "Action" 🙂
I just wanted to add that you're missing a quotation mark at the end of your code. With that small correction, it works great!
Best regards
