Ah, here we go, perhaps you can work off of this:
Server Error in '/' Application.
Could not load file or assembly 'AjaxControlToolkit' or one of its dependencies. Access is denied.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileLoadException: Could not load file or assembly 'AjaxControlToolkit' or one of its dependencies. Access is denied.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'AjaxControlToolkit' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileLoadException: Could not load file or assembly 'AjaxControlToolkit' or one of its dependencies. Access is denied.]
System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +43
System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +127
System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +142
System.Reflection.Assembly.Load(String assemblyString) +28
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +46
[ConfigurationErrorsException: Could not load file or assembly 'AjaxControlToolkit' or one of its dependencies. Access is denied.]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +613
System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +203
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +105
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +178
System.Web.Compilation.BuildProvidersCompiler..ctor(VirtualPath configPath, Boolean supportLocalization, String outputAssemblyName) +54
System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) +8809426
System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) +128
System.Web.Compilation.BuildManager.CompileCodeDirectories() +265
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +320
[HttpException (0x80004005): Could not load file or assembly 'AjaxControlToolkit' or one of its dependencies. Access is denied.]
System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +58
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +512
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +729
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +8890735
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +85
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +259
