Srikanth08
I need a report to find in how many systems Skype installed
Computername, username and software name (skype) and its version and installed on date
Regards, Srikanth08
Srikanth08
Thanks for the query
Regards, Srikanth08
Please use the report below for the information you are after.
Select tblComputers.Computername, tblComputers.Domain, tblComputers.Computer,
tblComputers.Firstseen, tblComputers.Lastseen, tblComputers.Userdomain,
tblComputers.Username, tblSoftware.softwareName, tblSoftware.softwareVersion,
tblSoftware.SoftwarePublisher, tblSoftware.Installdate,
SkypeCount.[Total Skype Installations]
From tblComputers Inner Join
tblSoftware On tblComputers.Computername = tblSoftware.ComputerName,
(Select Count(tblSoftware.ComputerName) As [Total Skype Installations]
From tblSoftware
Where tblSoftware.softwareName Like '%skype%') SkypeCount
Order By tblComputers.ComputerUnique, tblSoftware.softwareName,
To use the specified report, do the following:
• Open the Lansweeper configuration console and select Reports & Alerts\Report Builder. Hit the “New” button.
• Copy the SQL code provided and paste it at the bottom of the newly created report, replacing the default SQL code.
• Click somewhere near tblComputers so the new code applies.
• Give the report a “View name” and a “Report name” and hit the “Save” button.
• Double-click on the report in the report list to see its results and export options.
