olliedo
I have a few Macs and Linux machines that I use LsAgent to scan. The scanning works great, but every time one of them comes up/down I get a notification in lansweeper cloud. Since many of these machines are laptops, I don't really care about their power status and would like to, at minimum, omit these notifications from the "System Notifications" tab of the webui and, at best, disable this logging completely. Screenshot of what I'm talking about attached below. Thanks!
olliedo
Still seeking a solution for this. We'd prefer to use IT agent to LsAgent but the notifications are incessant.
FrankSc
Hello Olliedo,
Are "Granite" and "redacted_hostname" effectively scanned with LsAgent only? We don't expect to see notifications from LsAgent scans there.
Can you check if there is no other scanning agent installed on these devices? IT Agent?
In that case, the notifications can come from that client. We are still working on improving these notifications.
Apologies, these assets do use the IT Agent, not LsAgent. I'm still seeking a way to disable/silence these notifications if possible.
