golhelpdesk
I would like to add software licenses to the list under Lansweeper management console that currently may not be installed on any computer on the network. I click on the plus sign under the "Software for which you want to keep track of the licenses" section and though it does give me a blank record, it does not allow me to input information.
Any suggestions?
This is by design.
But you could use the sql management tool and directly edit the table tbllicenses
