kevinwdc
I was running Lansweeper 4.0 with SQL Express 2008 but the database reached its 4GB limit. I reinstall Lansweeper 4.0 but this time pointing to SQL 2008 and getting the error message below when access the Lansweeper Web Console. I also try to reinstall pointing to SQL 2005 and also get the same error.
Do you know why I am getting this error or how to fix it?
System.Data.SqlClient.SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
at System.Data.SqlClient.SqlDataReader.SetMetaData(_SqlMetaDataSet metaData, Boolean moreInfo)
Thanks,
Kevin
Please check your web.config file.
In the connection string you can see to which server the website is pointing to.
