laurentiun
I moved the database on a new server. Checked the files in program files with the password: "mysecretpassword0*"
From the webpage i have this error also other errors:
System.Data.SqlClient.SqlException: A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
If i'm trying to make the user "db_owner" from SQL Server - Security - User mapping click on the lansweeperdb - db_owner
I have error 15023 user, group or role lansweeper already exists in the current database
Please help...
1) Remove lansweeperuser from the database
2) Remove lansweeperuser from the database server
3) Recreate the user with the correct password and make it db_owner
