TheRickOlson
We are currently scanning all of our switches, and we get great data back. However, even though we're set to scan switches every 4 hours, if a device has moved around on the switch it will show up in multiple locations as being offline. Is there a way to trim or purge the switch port data? Maybe only keep the last 24-hours' worth of device connections?
You can use the option "Remove Disconnected Devices" on the switch's asset page.
remove disconnected devices
TheRickOlson
Thanks! That'll work perfectly!
