ccdesktop
Hi - I have performed the upgrade - but when I launch the web console i now get
Any ideas...
System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.web40totaldomain'.
System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.web40Devicecount'.
Device overview
Add new device
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
6 REPLIES 6
Download from http://www.lansweeper.com/files/lansweeper352.zip
ccdesktop
To do this I will need to reinstall LS 3.5.2 - do you have the install files?
I assume I would need to run the upgrade script manually?
We're in a mess now - nothing is working!
You can create a copy of the existing database and perform the upgrade while still using the old version simultaneously.
ccdesktop
Hmmmm.
This is not great!
I have been attempting to upgrade to v4 for several days now!
It is a shame that the process is so long winded if you have several thousand computers in your org.
Is there no better / faster way of dealing with these sceanrios.
We have been without the lansweeper resource for days now and it causing a big headache,
I'm tempted to roll back to 3.5.2 and stay there!
I wish there had been more info in the doucmentation about upgrading large databases.
You will need to roll back and do the upgrade again.
ccdesktop
I see from investigation - that the upgrade cannot have completed properly.
Of my 5000+ computer objects only 3126 have upgraded - so the rest of the script hasn't completed either.
Is there any way of getting this to pick up where it stopped or would I need to roll back and perform the upgrade again?
Hope you can help.
