Martin
I've just upgraded 4.0.0.11 to the latest one and here are my comments:
- after the upgrade had finished I couldn't open the LS website
After a short investigation I noticed that the file web.config was different from the old one. First difference: missing Data Source value, the second difference: missing the authentication section (the LS website must be accessed by domain admins only). But after the manual tune-up of the file the website opened fine.
- the IIS settings were overwritten as well (in my case Integrated Windows authentication checkbox got cleared)
- the installation program said it's updating ver. 4.0.0.11 to 4.0.0.17 but now the LS website says 4.0.0.16;
I know it's a very minor issue but you might want to know;
LS is installed on W2k3 SP2 Standard Edition.
I was running the upgrade twice: first time I upgraded all but the website and the LS website opened fine; second time I re-ran the installation to upgrade the website only. And then the above issues turned up.
But summarizing - all working fine now and I like the bug fixes.
By the way, I was going to ask about this earlier but never had time: after around 30 minutes of inactivity LS seems to have problems 'waking up', it takes ~5 sec. to open a link or look up a user/PC. After that it's working fast. To me it looks like a database issue however I didn't have that problem with ver. 3.52; but on the other hand the beta database was placed on a different server where the LS installer installed SQL Express and created that database from scratch. I tried to divide the IP ranges to smaller chunks in LS Configuration but it made no difference. Any ideas?
Cheers,
Martin
Thanks, found the problem
Martin
web.config from LS 4.0.0.11 got overwritten. And I do not have the 'corrupted' one but I will try to re-create (AFAIR).
I'm attaching the following files:
web.config(1) -> from LS 3.52 which is still running in a production env.
web.config(2) -> the dodgy one created during the upgrade 4.0.0.11 > 4.0.0.17
web.config(3) -> the one repaired by me which seems to be working OK
If it comes to the performance issue - I looked through event logs for any sql server warning/error messages but found nothing. At the time when the 5-sec pause happens no event are getting generated too. The system event log has plenty of the following errors:
DCOM got error "The RPC server is unavailable. " from the computer (IP's of some PC's on our ntwrk) when attempting to activate the server:
{8BC3F05E-D86B-11D0-A075-00C04FB68820}
But they do not get logged at the time the "delay" problem occurs.
Martin
Could you post your original web.config file please.
Was the original setup also on 2 different servers?
Please check the eventviewer for sql server related events.
