Katgroup
Hi Sweepies!
If you're using ManageEngine, please exclude Lansweeper from automatic updates in ManageEngine!
The upgrade script for Lansweeper 12.5.1.1 pushed out by ManageEngine incorrectly performs a clean installation of Lansweeper and sets your database connection to a new LocalDB instance. If you're already using LocalDB, this will result in data loss.
We are contacting ManageEngine to resolve this.
If you're using LocalDB, you should restore from a backup:
If you're using SQL Server, you can correct the data source and database credentials in ConfigEditor:
If you're using a custom port for your web console, you will have to correct this as well. See step 2 here:
0 REPLIES 0
