plangham1
Hi
I have just upgraded from 4.0 to 5.0 of LANSweeper and although the upgrade seemed to be fine I know cant hit the web console page with the below error message:
Line 8: <authentication mode="Windows"/>
Line 9: <identity impersonate="false"/>
Line 10: <compilation debug="false" defaultLanguage="C#" strict="false" explicit="true" targetFramework="4.0">
Line 11: <assemblies>
Line 12: <remove assembly="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
I have added the LansweeperAppPool to the application pools and made sure that .NET 4.0 was installed.
Please can you assist?
8 REPLIES 8
- For upgrade problems, please contact support@lansweeper.com
- For user access problems, please contact support@lansweeper.com and provide us with a screenshot of the Configuration\Website Management\Website Access section of the Lansweeper web console.
-Ent_R-
I always receive the following error in Internet Explorer:
Notification: AuthenticateRequest
Handler: ExtensionlessUrlHandler-Integrated-4.0
Error Code: 0x8009030e
Physical Path: C:\Program Files (x86)\Lansweeper\website
Logon Method: Not yet determined
Logon User: Not yet determined
-Ent_R-
I already added an AD security group to all the roles in the web console (I was only able to do this when anonymous authorisation was enabled).
After adding the group to the roles, I disabled the anonymous access, but I couldn't log on.
Also, the ResetWebUserRoles tool did not work.
plangham1
I had exactly the same...
I have resolved this by creating a security group in AD with limited members and added this to the Website Access under Configuration for ALL the web roles... leaving blank I think means anyone can access.
I hope this helps.
-Ent_R-
I have exactly the same error.
I did an upgrade from 4.2 to 5.0.
I am unable to login to the console.
I have the following configuration:
- In IIS, the website is bounded to the Lansweeper AppPool
- Pool: Framework version v4.0.30319 and Pipeline mode is Integrated
- web.config:
<assemblies>
- IIS authentication: Anonymous authentication = disabled, windows authentication = enabled.
When I enable the anonymous authentication in ISS, I am able to access the web console. But we don't want our regular users to see this console.
What's am I doing wrong?
plangham1
It appears that Classic Pool was holding the application so I have ammended this and now have the first run wizard.
plangham1
I am no expert when it comes to IIS so please can you explain how I go about mapping this?
Make sure that LansweeperAppPool is mapped to the Lansweeper application.
Most likely the website is mapped to a different application pool.
