hlteif
Hi again, I discovered that some of the workstations were not discovered by the lansweeper. did anybody get the same problem ? in case what was the solutions or hints to troubleshoot this kind of problem?
thank you
8 REPLIES 8
hlteif
Windows XP SP2
On which OS are you running the service?
hlteif
Please find in attachment the errorlog.txt
The errorlog should be in the same folder as your lansweeper service
c:\program files\lansweeper\service probably.
hlteif
where can I fond the errolog.txt ? no they are not offline. I did a test that consists of connecting to those workstation thru computer management and it works fine.
Could you please post your errorlog.txt file please.
It's also possible that these computers are currently offline or haven't contacted any domain controllers yet.
hlteif
I use active scanning. the version of lansweeper I am using is 3.5.0.48.
Do you use active scanning or lsclient?
