TK
Since upgrading to v11.1.1.3 from 10.6.2 I am having issues with deployment.
The error I am getting is:
failure while connecting to Asset: The operation completed successfully. Path: \\xxxxx.xxx.xxxxxxx.com.au\C$. ICredential(s): Global (xxx\xxxxxxxxx)
This only happens on the first time I am attempting a deployment to the target machine since the Lansweeper upgrade. Attempting the deployment again after the failure is successful.
Wondering if it is just me, or other people are also experiencing the issue.
12 REPLIES 12
markh65
Any update on this issue?
tenupmoc
Hi, you are not alone.
We have exactly the same problem.
Mister_Nobody
Honored Sweeper II
You have to create support case!
https://www.lansweeper.com/contact-support/
