Pealik
None of the powershell script deploys work. I get the error message:
Result: Deployment ended: Unknown error (0xfffd0000). Stop(Failure).
To run the script I use the command:
powershell.exe -executionpolicy bypass -File "\\Lansweeperserver\DefaultPackageShare$\Scripts\SubScriptfolder\powershellscript.ps1"
If I open CMD on the local machine with the Lansweeper Scanning Cred user and type in the same command
then it works just fine.
Also running the scripts over Lansweeper worked a few months ago. Please provide a quick explanation/solution as work is disrupted.
FrankSc
Hello Pealik,
The "Unkown error" is difficult to troubleshoot. The task scheduler does not always provide clear feedback on what went actually wrong.
If the script runs locally, I do think it might be a credential or permission issue. Maybe there is an issue to get/fetch the script from the shared folder.
Or maybe you could try running it with the "system account" or "currently logged on"?
Deployment Packages
Share topics/ issues related to deployment packages. Please use/rely on content with caution as it is publicly generated.
