‎01-30-2014 01:45 AM
Solved! Go to Solution.
‎01-30-2014 10:11 AM
Is there a reason why LS does not pull the Operating System field from AD when it scans?
Also, our AD scanning pulls 3290 computers but when I run an AD scan using ADManager it pulls 3545 computers from the exact same OUs, why would this be?
‎01-30-2014 06:05 PM
Lansweeper wrote:Is there a reason why LS does not pull the Operating System field from AD when it scans?
We stopped scanning this value because in many cases the results were incorrect (different from the real operating system).
‎01-30-2014 08:27 PM
ukaussi wrote:
Can we enable this on our server/version?
ukaussi wrote:
If not, is there a way to edit the OS field or "OScode" value for each of the "not scanned" assets as this field is not editable on the mass edit screen?
‎01-30-2014 09:46 PM
Lansweeper wrote:
You can manually edit the OScode field in the tblAssets database table, though this is not supported. Your changes will likely be overwritten upon rescanning as well.
‎02-10-2014 10:06 AM
ukaussi wrote:
Just to clarify, will they be overwritten by "not scanned" if LS is unable to scan the asset?
