‎09-06-2018 10:16 AM
I am trying to prepare for a huge software upgrade this weekend in my practice and wanted to remote install the various Autodesk software. I have followed the Autodesk instructions to prepare a deployment version and created a package. However, it keeps failing and i can't work out why. Any help gratefully received.
General Discussion
‎05-25-2020 05:57 AM
‎09-07-2018 03:32 AM
I have found it best to copy locally to the machine (temp folder) install, then delete temp folder.
‎09-07-2018 01:52 PM
CyberCitizen wrote:
Yeah Autodesk products have been the bain of my existence here, due to their size and our staff alot work from 4G Dongles (Celluar).
That's what i was doing originally, but with 59 PCs it is a right pain to do! If you like, i can share my deployment packages for each (of course you have to do the "create deployment" from the product first) along with a combined patch deployment package.
‎09-06-2018 05:21 PM
Must be that the install required full administrative permissions (which are the scanning credentials).
‎09-06-2018 05:00 PM
Thank you for the help
‎09-09-2018 02:36 AM
MasterDoddy wrote:
...it seems to only work with Lansweeper if it's deployed used Scanning Credentials and does not like System Account...
thanks for this! I also happen to be in the midst of an AutoDesk upgrade this weekend, and while I'd swear my deployment pkgs were working from lansweeper a month ago, they weren't yesterday, and I couldn't figure out why, until I found this thread. fixed my issue! Best of luck with your upgrades!
‎09-06-2018 04:21 PM
To test the deployment command, you can do the following:
- Copy the Result command of the failed deployment package step
- Replace {PackageShare} with the exact path defined under Deployment\Security options
- Paste the command into a command prompt on an example target machine and run it.
‎09-06-2018 11:43 AM
Result: Deployment ended: Incorrect function. Stop(Failure). Credential: (Service account - NT AUTHORITY\SYSTEM). ShareCredential: (gfa\simon.dodd).
Command: "\\CDF-GFA-DCF-02\gfadata$\Practice Admin\__GFA IT\PackageShare\Installers\AutoCAD 2019\Img\Setup.exe" /W /qb /I \\CDF-GFA-DCF-02\gfadata$\Practice Admin\__GFA IT\PackageShare\Installers\AutoCAD 2019\Img\AutoCAD 2019.ini /Trial /language en-us
‎09-06-2018 11:03 AM
