EB
Our Lansweep is reporting
Antivirus: avast! Antivirus Enabled Outdated
Every workstation....but the defs are good to go.....where is the scan failing...or where do I need to adjust it?
thank you
The antivirus information is scanned from WMI. I would first do a manual rescan of the asset by using the "Rescan Asset" button on the asset's page. This will force a full rescan of all the items.
If after the rescan the information is still incorrect, then the computer's WMI will also be incorrect. If this is the case you can try rebuilding the WMI class as mentioned here: https://www.lansweeper.com/kb/123/managing-anti-virus-software-reports.html#heading1
EB
Uh....YEEEEEEAAAAAHHHHHH.....If you could go ahead and make business avast recognized in lansweeper....that'd be greeat.....ok...?
It is only the SERVER VERSIONS
