Pollak
How does one add the Service TAG number to a column in Computer: System configuration overview?
Thanks,
Niles
Open the report builder.
Edit the existing report
Add and link table tblcomputersystemproduct
Add field identifyingnumber
Pollak
Awsomme, now how can I get the hyperlink on the tag number just like in the Action pane?
Thank you ,
Niles
You can't do this in a report.
