ErikBerserk
I am encountering  this problem;
I am trying to deploy a script throughout deployment tab to 200 client.
When i first run the deploy, it run successfully only for a bunch of them (around 30 clients), the others return an error; Result: Deployment ended: Incorrect Function. Stop(Failure).
The fact is, if i run it again, another bunch of previous failed machine, now runs successfully.
The problem is, this need to be executed as much times until all are completed successfully.
Do you know what the problem may be?
Obi_1_Cinobi
Hello there!
To troubleshoot deployment issues, we would recommend reaching out to support: https://www.lansweeper.com/contact-support/
